Tado Extension and Ideal Independent Combi 35
10 Nov 2020
Morning all
Hoping someone can help me, I have wired up the extension kit as per the instructions from TADO however, it will not call the heating.
I have the grey wire connected to the terminal 4 on the tado extension and to the room stat / timer block in the boiler.
I get hot water however, I cannot get my heating to come on.
I had an ESI digital receiver connected previously and that had 2 wires from 1 & 2 on the receiver panel connected to both the terminals in the boiler.
I now only have 1 wire connected to the the Room Stat / Timer block as per the instructions. However NOTHING..
Please can someone help me?
Dougie
The Tado usually replaces the existing programmer that controlled the heating and hot water on/off periods I say usually....
....but, I'm a bit puzzled when you say you have a combi boiler, but then refer to the Tado controlling the hot water. Normally the hot water control with a combi is on demand when a tap is opened and not connected to any external controls. So depending on that there are two different solutions.
I assume the old ESI receiver looked like this:
SOLUTION 1
If you didn't have a two channel programmer, then the Tado simply replaces the ESI receiver. The wires are moved from the ESI terminals to the Tado terminals that have the same function.
ESI N to Tado N
ESI L to Tado L
ESI COM to Tado COM
ESI NO to Tado NO
Make sure the Tado jumper is in Position 1
SOLUTION 2
If you did replace a two channel programmer with the Tado, then the old room thermostat receiver needs to be decommissioned properly and a small wiring modification made to complete the circuit, it can't just be removed otherwise the wiring will be open circuit and the heating won't operate.
Then the wires that were in '1 COM' and '2 N/O' should be joined together to complete the circuit. This can be done at the receiver end, or preferably at the origin of the cable, then the receiver cable can be removed completely.
Unfortunately telling us the colour of the wires doesn't help. The wire colour would have been chosen by the original installer at his discretion. It's what the wires are connected to at each end that determines their function, not the colour of the insulation.
HI Stem
Thankyou for the reply! My hot water is on demand! sorry for the confusion..
That is the exact receiver I did have that was connected to my boiler. 1 & 2 on the receiver were connected to the stat / timer block on the boiler.
I have replaced this with the TADO extension. With only pin 4 on the TADO extension connecting to the Stat / Timer Block (as per TADO instructions)
MY original thermostat was wireless.
So could you tell me how I wire the TADO receiver to the boiler? should I be connecting more wires?
Dougie
For just replacing the ESI receiver with the Tado, the wires swap over like for like from the ESI terminals to the Tado terminals that have exactly the same function:
To:
So:
ESI N to Tado N
ESI L to Tado L
ESI COM (1) to Tado COM (1)
ESI NO (2) to Tado NO (4)
Hi Stem,
I have these pictures of the original wiring
Pic1 1 : Is how the ESI receiver was wired
20201108_161321-jpg.210939
Pic 2 : This is how the boiler was wired
20201109_171628-jpg.210940
Where the blue wire goes into the Room Stat / Timer block, I have one wire now that goes from there to terminal 4 on the TADO extension box.
Hopefully I have explained that well?
Thank you!
Dougie
What readings did you get on your FGA and gas rate after putting boiler back together?
