- Joined
- 10 Nov 2020
- Messages
- 12
- Reaction score
- 0
- Country
Hi I have a drayton LP241 connected to a honeywell T40 stat.
It's a back boiler system with a hot water tank.
https://ibb.co/tJy8209
this is the wiring i have into the controller
https://ibb.co/jkNxp3T
and this is the wiring i have into the stat.
There is also a wiring centre box which has a ton of wires going to it.
I replaced the controller wiring up as a direct replacement for the hive as the terminals are the same. I disconnected the far right terminal on the stat
The hot water worked but the heating didn't.
You will notice there is a chock block on the controller,
This is live and goes to terminal 3 on the stat, ( 3rd from the left on the stat)
and the Pin 4 on the controller (far right) goes to terminal 1 on the stat (far right)
do i have to do anything with regards to the stat?
Any help gratefully accepted thank you
