Hi I have pressure of 1.5bar about 14L/min flow rate with 2 thermostatic showers and so was thinking Ill get a a combi that heats about 14L/min. Worst case is Ill get 2 showers 7L/min which is okayish.
However someone suggested unvented cylinder if 2 showers but how will this give me more L/min as don't you just get out what you get in.
Was looking at the helpful ladies at heatinghub and suggests if pressure is good and multiple showers on simultaneously then use unvented, and they don't consider flow rate.
So if unvented would I get 14L/min out of both thermostatic showers?
I have had an unvented before briefly in a rental house and I recall the shower flow/pressure dropping off lots if someone had another shower hence my working assumption you just get out what you get in even with unvented
