- Joined
- 3 Dec 2020
- Messages
- 4
- Reaction score
- 0
- Country
Hi all.
My sister wants her cooker switch moved just a centimetre up and to the right so it can be clear of the edge of her tiles. The switch was, weirdly, installed right on the edge of her tiles on two sides and the tiling trim was cut to fit it. No idea why they didn't put it slightly higher and over as it would have matched the other sockets.
It is a standard metal backbox that I plan to leave and just mount a new 47mm surface box with a new switch plate and fill and seal the gap around just the surface box.
Having had a look, I see that the wires are just too short and will not pass through the new surface box and reach the switch terminals.
It is 4mm cable on a 32A MCB on an RCD leg of the CU.
Can I use something like Spliceline connectors to extend these wires or will the inrush current pop the connector? It is feeding just an oven, no hob.
I do not have room to install a large connector block in the backbox as it's a 25mm one! (I have no idea how they managed to squeeze everything in in the first place...)
Your esteemed advice would be much appreciated as the management will not be pleased with the ideas of a new piece of surface trunking running down over her tiles and through the solid wood worktop...
Thanks all.
- Al
Thanks all.
- Al
