The quality of Ikea kitchens is said to be good but not better than Howdenswickes comes flat packed as do IKEA, used the wall units to cover a utility wall floor to ceiling in cupboards worked great
AFAIK it was firms like B&Q and Argos going into furniture sales which started the rot, followed by the entry of IKEA into the UK. IKEA are a different operation to what MFI was, making a "day out" out of shopping with everything you need for the home (from cutlery to furniture to house plants) which MFI with its' smaller sites couldn't hope to compete. BTW, when IKEA finally got here they were already operating in 6 or 7 European countries (in the 1980s I remember seeing branches in Germany, Denmark and the Netherlands) and were already much bigger than MFI or Habitat (another firm who started a downward trajectory when IKEA came to this country)Why did a massive company like MFI not manage to succeed whereas Ikea managed to and they were both doing the same thing eg flatpack style ...
The last Howdens kitchens I installed went into council offices about 4 years back. I'm pretty sure they had 8mm thick MFC backs. Because they specified massive water heater/filter combos to be installed it was necessary to modify some of the base units to accommodate these beneath the sinks, so we installed 18mm pre-edged MFC upstands at the back (about 250mm tall - above that the wall was visible, at least until the heater went in)You change the cabinet backs? What are Howdens backs like because someone mentioned there backs were a little bit thin...
I think a competent DIYer should be able do the jobWould I have to hire a carpenter to be able to do what you do to the flatpack?
No, but you can considerably improve the rigidity of the carcases, strength of the backs and of the drawer bottoms. Whilst you can't improve the quality of the carcasses much (for example it is nigh on impossible to replace an "iron on" 0.6mm melamine edging with a 3mm PVC edging that has radius edges) you can install your own wire work, putting stronger backs, fit stringer drawer bottoms and seal all cut chipboard edges (with clear lacquer or sllicone for better moisture resistance - especially on the sink unit). Not all fitters sell back edges. TBH a good install by a competent fitter can make all the difference to whether your kitchen is just OK or excellentWould you say that by doing the flatpack kitchens like you do with the additional quality would they then be equivalent to Howdens solid carcass units?
How do these compare with the other flat packed kitchens?Theyve added four plastic clips that screw through the back panel into the main frame which does stiffen and take all movement out.
Professionals have rated them as being good value for money and good qualityJust had a Shereton kitchen installed. Excellent quality, but twice the price of DIY kitchens on Yorkshire that my nephew used, and his cabinets and doors look identical to mine. He even had a colour choice that I didn’t, any Farrow and Ball colour. If I had to do it again, I’d absolutely use DIY of Yorkshire.
Understand that, one reason we bought from a local supplier. SIL even took a trip uup North, to see the showroom before committing. Unfortunately I’d ordered mine before he’d fitted his.I haven't personally seen them but I know people who are "authorities" on good kitchens such as tradesman who fit them have rated them as being good value for money and good quality as well. I don't like the idea of them being so far away though so I'd probably stick with Howdens because I like a physical place where I can go in and sort out any general issues that come up
I can fault is that the screw for the handle on the corner unit has scratched the door of the unit next to it
I’ll always do that now so guess the fault was really mine not theirsI always recess the screw heads on handles on corner units for this very reason, but of course learned to do this the hard way...
Yes, I used DIY for a bespoke painted kitchen 2 years ago and still perfect. Also, we got the granite worktop through them. they subbed it out to natural stone surfaces, and very impressed with them - top job.
