C
Captain Nemesis
So the use of the building has no bearing on whether the building requires PP?Btw, it's the building that requires permission not the use.
Also theres no requirement for it to be feasible to move it assembled to or from its location. I.
I can also write from a position of knowing what the TCPA 1990 says, and I would suggest that trumps the obscure "beat the system, say it's a caravan" approach based on random (and unsubstantiated) google searches.As I said - you can write about what the Caravan Act says from a position of knowing what it says, or from a position of not knowing what it says.
Its up to you.
Are we still talking about garden rooms or are we drifting into Use Classes?So the use of the building has no bearing on whether the building requires PP?
Can you quote the bit where it says that it repeals or nullifies in whole or in part the provisions in the Caravan Act?I can also write from a position of knowing what the TCPA 1990 says, and I would suggest that trumps the obscure "beat the system, say it's a caravan" approach based on random (and unsubstantiated) google searches.
We are talking about the fact that you could have two identical buildings in identical situations with one needing PP and the other not because of the way that one of them is used.Are we still talking about garden rooms or are we drifting into Use Classes?
Have you googled planning appeals where it was ruled that installing a portable building did not count as development?Have you googled "operational development" yet? s55 of the 1990 Act if it helps.![]()
It must surely be a thing that the gypsies want kept to themselves.
I'm not, nor are my neighbours. There are planning conditions and covenants preventing it.Maybe youll be able to cope better if we take it one step at a time.
- Are people allowed to put a caravan in their garden?
Once youve answered that we can move onto the next stage.
Not if you live in a flatDo those conditions and covenants apply to everybody in the country?
