- Joined
- 7 Dec 2020
- Messages
- 22
- Reaction score
- 0
- Country
Hi all,
I have recently bought a house (1920s/30s) and want to insulate my loft. Currently there is about 100mm of fiberglass between the joists and floored with chipboard. I really need the loft for storage so rather than add extra glass wool I want to use multifoil under the rafters - it looks relatively straightforward. Using multiple layers can achieve a U value without adding insulated boards between the rafters too (or so the manufacturers claim).
Anyway, my roof is old but seems solid, the loft is dry and very draughty so well ventilated, however, there is no membrane under the tiles - which is not uncommon among houses this age. The tiles back directly into the loft. Also the rafters are very narrow and shallow. Multifoil would also help with keeping my loft dust free as currently a lot gets blown in.
What I don't want to do when or if I use the multifoil is to cause problems with condensation or damp, between the insulation and the roof. They claim it is breathable but as there is always an assumption of a breathable membrane under the tiles during insulation I want to make sure I'm not causing a problem down the line.
Help and advice gratefully received
