Our bathroom has recently been tiled in 300 x 600 x 10mm porcelain tiles. For the first time I've encountered the difficulty of drilling through porcelain and even when using purpose made diamond drill bits, it still takes some time to get through!
Above our basin, there is an electric cable poking out of the wall (runs down the back of the plasterboard), which was installed for use with a LED mirror. The missus has now chosen her mirror, unfortunately the cable is in the wrong place!!! 3/4 of the back of the mirror will fit flush against the wall and the last 1/4 is where there is space for the cable and the connections to the mirror. Unfortunately for me, the cable needs to be moved 10cm to the right, I'm therefore considering cutting a narrow channel in the tile so the cable can be run to the required place.
I hate the fact I will have a nasty channel cut through the tiles, but I think this is unavoidable and there will always be a mirror in place to cover it up!
What is the best way to cut this channel?
I have plenty of different tools to try with:
- Fein multimaster - I suspect this would just take too long!
- Angle grinder (small). A possibility with the correct diamond cutting discs?
- Mini circular saw. Possibly not as controllable as the angle grinder, but I do have some diamond tipped discs already.
I would appreciate your thoughts/experience.
