Hi All,
I think I made a big mistake when finishing off part of my shed.
I insulated a partitionof the shed whish is kept at around 30 degrees.
I have 9mm OSB, 100mm glass wool, 18mm OSB, breathable membrane and then corrugated roof sheets.
Above the insulation is soaking, I guess it's because I should have put a vapour barrier after the 9mm OSB.
I'm getting the same issue in the walls.
Is there anything I can do to resolve the issue? Is there a paint I could put on the inside of OSB?
Thanks in advance
Thanks in advance
