Adjusting UPVC Front Door
16 May 2014
Aberdeenshire
Hi
My UPVC front door seems to have a gap at the top letting in a draft. From inside the house looking at the door, with hinges on the left, there is a gap at the top right of the door. Its as if it needs lifting it up at the right hand side. There is 3 hinges on the door. How do I adjust them to level up the door and get rid of the gap?
Can you post a pic of the hinges quite close up (including a pic showing the side where they screw into the frame and door i.e. taken from other side when door's open) and a pic of the gap?
Here is some pics. Of the 3 hinges it looks like the top one has popped out somehow and is hanging squint? The gap is at the top right of the door, not sure if it can be seen clear enough.
For reference they're flag hinges, can be adjusted for height (up/down) lateral (left/right) and compression (in/out.)
How To Adjust uPVC Door Flag Hinges (windowware.co.uk)
It's difficult without seeing it in person but it certainly looks as though the top hinge has either loosened or failed, especially when looking at the 3rd pic down. If you take the front hinge cover off you'll see if any of the screws holding the hinge onto the door have come loose. Will also make it easier to see if its failed. If the gap has only appeared recently then something's changed, either failed hinge or door has dropped. If hinge is fine the door either needs toe and heeled and/or hinge adjustment to correct top right misalignment.
toe & heel
How to Toe and Heel a Door | MPL Locksmith Training (mpl-locksmith-training.co.uk)
hinge adjustment
How to adjust PVC door with an Allen / Inbus Key - YouTube (there are better instructions out there however this gives you a visual idea of what's required)
toe & heel
hinge adjustment
I hope you’re well. I’m writing to let you know that the UPVC front door appears to have dropped slightly and is becoming difficult to open and close properly. It seems to be catching on the frame, and the locking mechanism is not aligning as smoothly as it should.
