- Joined
- 16 Dec 2020
- Messages
- 84
- Reaction score
- 1
- Country
Hi all,
I've got a steel Durabase conservatory base to install and these require 5 concrete pads measuring 400mm x 400mm x 400mm for the steel base "feet" to sit on but on looking at a lot of you tube videos i've seen quite a few use concrete foundation blocks and then just fix them in place with ready mixed concrete as opposed to filling the entire hole with ready mixed concrete but given this will hold not only a 3m x 3m steel base it'll also hold the floor to ceiling windows and a flat roof are these ok to use ? the one's i've seen are only around 3Nm or up to about 7Nm strength bearing.
Anyone fitted these as a foundation at all as these seem a LOT cheaper (and easier) than pouring 0.5m3 of concrete in there ?
