chase copper pipe
19 Dec 2020
I have a cold water pipe that is running along my wall for my downstairs toilet. I would like to chase it into the wall, so that I can then put tongue and groove over the top without the box at the bottom. Is this okay to do? Will it be a problem if I chisel into the breeze blocks?
full
Sorry, what do you mean "don't chase?". Do you mean don't let it touch the breeze block? I've since read that it's not good for copper pipes to touch breeze blocks.
No, don't cement/plaster the pipe in to the chase, no need to when covered up. Chase is a chiselled groove in the blockwork.
Ok. Thank you. So just chisel out a long line, and then screw into the breeze block? Should I use any foam or anything? Structurally is it okay for me to cut a strip into the breeze block about 1.5m? Because I am moving the pipe in (if only a couple of cm's what is the best way to extend each end of the pipe? Learn to solder a corner or use something easier?
Just done exact same today with rad pipes for new rads... Vertical rads, so narrower span... Chased out walls behind skirting to bring pipes closer together... One wall was breeze blocks so was easy... The other wall was the old exterior wall of the house (inside extension) and was the toughest engineering blocks I've had the displeasure to chase into! :sick:
Behind skirtings so only filled in chases that pop above skirting. (y)
Sorry may have read post wrong but i think you want to remove the box section as well ? and to tounge and groove all the way up from floor ?
As behind the box section is your waste pipes.
If i have read it wrong sorry
Hi, Yep, going to remove the box and yes there will be a waste pipe, but I am going to get a vanity unit to hide all that.
