Minor electric shock with the power off... faulty circuit breaker?
Did you use tester on live and neutral, got a shock once with power off , live and neutral had been reversed.
I didn't have a tester with me when I was replacing the switch. I don't have one at present, but I can borrow one.
It's not that uncommon.
First time I found it I'd pulled the lighting fuse to work on a fitting then managed to short N together.
First time I found it I'd pulled the lighting fuse to work on a fitting then managed to short N & E together.
Can anyone indicate what it is I should be testing when I do get the multimeter, please?
Or is it more a case of turning off every switch on the main CU and then going upstairs to see if the bedroom lights are still on?
If you check voltage at that switch position with a multimeter between live and earth, with the main CU switched off and get a reading, then that light must be fed from elsewhere.
To put an end (one way or the other) to all the speculation going on here, could you switch off everything (just) in the secondary ('shower') CU and then tell us whether the bedrooms lights still work?
To my knowledge, this was fitted to supply the shower only.
Lazy ****ers couldn’t be bothered to write in what the two switches do.
You should now fill them in. The right-hand 40A one is the shower and the left-hand 6A one is (some of) the lights.
Can someone comment on the acceptability of having no “main switch”, but only an RCD and MCBs, in that second CU?
I switched off just the smaller "secondary" CU. Lo and behold, the shower went off (as expected), but so did 5 of the 8 upstairs lights, including the one I had been working on.
So it had been live whilst I was working on it.
I have written a large warning on both CUs now and labelled the 40A and 6A fuses in the "secondary" as advised.
Thank you one and all for your help!
None of this would have arisen if your shower installer had issued full certification.
In my defence, I'm just a layman.
I hired him to install the shower wiring, and that's all I thought he did.
I honestly didn't know he'd done anything else, he definitely never said he'd re-routed some of the lights, and no paperwork/certification ever changed hands (again, I wasn't aware that I should have received some).
Needless to say, I won't be using him again.
I would get an electrician to investigate exactly what he has done to your lighting circuit. I would have expected one light to ge OFF, and five out of eight seems odd to me
Depends on the layout of the house surely
