Experienced practical semi skilled construction worker doing skilled jobs?
T
teaboyjim
I've got someone interested to help get the refurb finished and say they've got experience but don't have a specific trade qual
Your idea would probably work if the guy can do what he says he can do up to a reasonable standard....
And if he can’t yer goosed pal ;)
Your idea would probably work if the guy can do what he says he can do up to a reasonable standard....And if he can’t yer goosed pal ;)
I've seen pictures and descriptions of jobs that looked ok
Only you know the guy, nobody is going to be able to tell you if hes teachable or not, and only you know if you are prepared to redo things if its done wrong while not supervising, and prepared for that cost.
I couldn't instruct or teach him but could objectively find out what he is good at and focus on that
there's a shortage of good builders where I live, they are all seemingly booked up working towards London and anybody local is busy as anything
When i choose a builder for the home, if they can start in a day or 2 then they need to have a good reason why, otherwise we have to wait a few weeks, In fact around october getting our electrician back to finish the next room on a full re-wire took 8 weeks !!! and to do a cloakroom, asking in August i was quoted by most of the builders we use, November at the earliest possibly later.So did it myself.
It is one of the signs of a good builder , unless a job fell through or just starting out on own
Yes I agree
I researched the question on how to plaster the inside exterior kitchen wall of this 100 year old house with solid brick walls and no cavity and got the correct answer from the community here but he gave the wrong answer when I asked him.
so what was his incorrect answer?
I can wait a few weeks or a month but not more than that
So you need to book them in NOW really. Also if you already have some builders in mind, thn also ask them , even if busy a gap can appear, jobs dont get agreed, budgets change, planning issues, weather
they may have a gap
Once you have a few builders you can trust, then make sure you keep them on the books for any future jobs. I have done this with a building team, and got them to quote for about 10 jobs I wanted to do in the year, then i know when ready I can talk to them to get booked in
So you need to book them in NOW really. Also if you already have some builders in mind, thn also ask them , even if busy a gap can appear, jobs dont get agreed, budgets change, planning issues, weather they may have a gap Once you have a few builders you can trust, then make sure you keep them on the books for any future jobs. I have done this with a building team, and got them to quote for about 10 jobs I wanted to do in the year, then i know when ready I can talk to them to get booked in
I'll start phoning around at the beginning of Jan
From a normal building job point of view it's been a total disaster due to the amount of time it's taken
But from all your other post, of you want to get into the game, a good learning process and you need to look at all the mistakes and understand the root cause to avoid next time, most people dont look at the root cause , just the symptoms and never really learn. Good to make mistakes, just don't make the same mistake twice.
Yes you're right
Have you got a list of what you need to do?
You would normally have a builder make any structural changes, plumber, joiner and electrician to do their first bit, plasterer in, then plumber, joined and electrician back to finish.
