- Joined
- 30 Dec 2020
- Messages
- 4
- Reaction score
- 0
- Country
Hi everyone, looking for a bit of advice on extending an existing radial circuit in my home (England, UK). I'm fairly experienced with basic electrical works, and regularly convert homes to 'smart homes', however the following has me stumped.
The house was rewired 5-6 years ago, prior to my purchase. Currently renovating so the ground floor ceilings have all been ripped down giving me easy access to the services.
Which of the following would you recommend as "best" (I suspect both are probably ok, with option B being the easiest):
A) Breaking into / splitting the radial (sorry about my terminology):
Or, B) Splicing into the radial:
A few other queries connected to the above:
- From my research I’m getting conflicting information about the number of permitted outlets on a spur:
- https://www.diydoctor.org.uk/projects/radialcircuit.htm - states that only a single outlet is allowed per spur
- http://wiki.diyfaq.org.uk/index.php/House_Wiring_for_Beginners - shows multiple outlets per spur
- Is the existing 16B MCB sufficient, from my research it should really be a 20A MCB? Some some sources state that 16amp is ok, others state that a radial must be on a 20amp MCB. Considering that I’m more than doubling the outlets, I suspect I need to upgrade to 20amp?
- Is it permitted to place junction boxes in the ceiling void (they will be inaccessible once the new plasterboard goes up). I don’t really fancy the extra chasing required to spur from the existing sockets.
- Are Wagos ok in the ceiling void, within Wago boxes of course?
