What are JB4 ports?
23 Aug 2015
I am looking to buy a LED driver for my G4 conversion to LED and saw this from Toolstation.
It states it has Integrated JB4 distributor ports. What are these? Do you buy JB4 connectors that you connect to the wires to plug in? Every time I’ve googled I get information about cars. There is almost nothing Ive found that explains what this means.
Has anyone heard of these and can someone point me in the right direction please?
https://www.toolstation.com/sensio-titan-12v-led-low-profile-driver/p84275
Whilst it's true that Googling for "JB4 port" (without the quotes) does, indeed, get hits relating primarily to cars, if you Google for "JB4 port LED" (again, without quotes), you'll get primarily more relevant hits.
A Lot of led stuff now uses small white plug and sockets, i quess thats there official name.
Quess there tricky to fit yourself not even sure you can buy the plugs
That’s disappointing as I have a lot of older G4 halogen lights that are all wired on a different connector.
Plan B, using the existing distributer box and see if it can be connected to the Driver somehow.
sorry wrong link. What I meant to post this. It says easy connections but I’m guessing only if your wires have this connection already otherwise it’s not really that easy.
Indeed - here's one with 12 JB4 ports (6 on each side) ..
Like you, I have so far found no plugs, but there are a few leads around , such as ...
Them drivers are proberly sold to be paired with the fittings they sell, theres many drivers with just basic terminals for you to wire in yourself.
Do you have a link to any that can be bought over the counter by any chance?
Yes, 2 core flat 0.75mm² as the 230V input, and the same for the 12V output.
If multiple lights are to be connected to it, a suitable junction box and connectors can be used.
Any existing connector on the light can just be cut off.
G4 lamps can be connected either way, polarity isn't important.
To be honest I don’t know what that lead connects to. I would prefer to bare wire it into a driver so I didn’t need to worry about getting the right connectors.
https://www.screwfix.com/p/aurora-12-240v-constant-voltage-led-driver-16w/2107t#_=p
Tooltation proberly do similar.
I assume your lamps are 12 volt just make sure its labelled CONSTANT VOLTAGE 12 VOLT.
look for a removable cover on the end, you will see Flameports is similar.
you can load this up to 15 watt total lamps.
Its unlikely you will get more than 2 wires in the output terminals so if there many lamps, you will need to wire out to a JB as Flameport suggests,
If thats the case you can get the Toolstation sensio ones and cut the JB4 box off
https://www.toolstation.com/sensio-led-driver/p13514
Though looks like Toolstation are phasing them out.
What is the total wattage you need
You mention a Plan B Existing Distribution box, you could likely repurpose this by cutting the input lead and connecting into the driver.
Are you sure that plan B box is not using the same Jb4 plugs you mention :)
I use these where converting smaller lights to LED, .
If I may ask, is there a limit on lead length to the light, as with the old halogen units, I have never seen one labelled as such and wondered why
