- Joined
- 29 Aug 2020
- Messages
- 134
- Reaction score
- 6
- Country
Where on the system would you recommend ? And what filter would be best ?
My boiler must be around 15 years old I'm guessing . Would the filter be used on a new boiler if I need one soon ?
Baxi 105ewhat is the make and model of your boiler ?
Just looking at my pipes .For some reason they are reduced to 15mm just under the boiler all them filters seem to be 22mmYes, but if you already have a decent filter fitted like the 2 mentioned above they won't replace it as they are good filters.
I'm confused , it's fitted the wrong way so I can use it ?your filling loop is fitted the wrong way round so yes you can use the express
Yes the non -return valve should be on the cold water pipe and the 1/4 turn valve on the heating return, so yours is the other way round, so just diconnect the hose at the 1/4 turn valve end and connect onto the expressI'm confused , it's fitted the wrong way so I can use it ?
Brilliant thanks , I might put the inhibitor in soon then ask my gas guy to fit a filter in the summer (with the annual service) . Pity you can't get a 15mm filterYes the non -return valve should be on the cold water pipe and the 1/4 turn valve on the heating return, so yours is the other way round, so just diconnect the hose at the 1/4 turn valve end and connect onto the express
just use two 22mm to 15mm reducersBrilliant thanks , I might put the inhibitor in soon then ask my gas guy to fit a filter in the summer (with the annual service) . Pity you can't get a 15mm filter
Ian, if fitted as you suggested how can the 'temporary link' be removed without making a mess?Yes the non -return valve should be on the cold water pipe and the 1/4 turn valve on the heating return, so yours is the other way round, so just diconnect the hose at the 1/4 turn valve end and connect onto the express
