Changed from Randall 102 to a Drayton 722
8 Jan 2021
First ever post so be kind, as the title says, Randall 102 wired
1dhw, 2htg, 3com, 4earth, 5N,6L, this is looped at 3-6
Drayton lp722
My understanding is that
N is N, L is L, 1- com, 2 is blank, 3 dhw, 4 htg, I've tried looping and not looping the loop between L and 1, I have heating and hot water, just not hot water only, I did put this on an old thread but got told to start a fresh post, thanks for looking taking the time to read it and any answers/ help anyone provides thanks
The Randall 102 terminals are as below....
and the Drayton....
lp722-jpg.131405
So the wires simply move from the Randall to terminals at the Drayton that have exactly the same function
Randall (1) DHW = Drayton (3) HW on
Randall (2) HTG = Drayton (4) CH on
Randall 5 (N) = Drayton (N)
Randal 6 (L) = Drayton (L)
No "loops" required anywhere at the Drayton. As you can see from the Drayton diagram the COM connections are made internally for you already and not brought out to an external terminal like the Randall.
The wires simply move from the Randall to terminals at the Drayton that have exactly the same function. So if there are two wires now in Randall N5 then both wires will go to N at the Drayton. If there are two wires in E4 both go to the Drayton Earth connection on the backplate.
You don't mention a wire in Randall DHW (1)? This is the terminal responsible for controlling the Hot Water, so should be present.
You don't say what sort of heating system this is controlling ie fully pumped (S-Plan or Y-Plan) or a system with just pumped central heating and gravity circulation of hot water. If it's the latter, the Drayon will need to be set to gravity operation. In this mode of operation, the hot water is automatically selected 'on' whenever the central heating is 'on'. This is because of plumbing restrictions in this type of system that require the hot water to be 'on' in order for the central heating to work.
Forgive me for not supplying those details, like everyone else I think people are mind readers, my apologies, cracked it, followed the 2 wires back and they crossed over half way up the wall, the heating was trying to control the water and vice versa, thank you for looking and replying, again very much appreciated
Yeah I was getting a little confused with the attached instructions, cos the 102 was a com, I assumed after reading this diagram that term 1 was a com, cheers for the reply
That diagram you have just posted is not for a Drayton 722. You said you had a Drayton 722 which is a dual channel programmer with heating and hot water control. The diagram you posed is a single channel programmer for only heating control. They are completely different beasts with different connections.
Drayton 722 dual channel programmer (Heating and Hot Water control)
lp722-jpg.131405
Single channel (Heating only control)
Hi thanks for your response, this is the bigger photo from my screenshot, must of been where I was getting the mistakes from
That is a standard document that covers every model of the LP programmer that Drayton manufacture. As you said that you have an LP722 which is a dual channel programmer, that should be the section you are looking at.....
unless of course if you have different model......
Yeah it's the 722 I have, all sorted now, thanks for your replies and feedback etc, very much appreciated
Having just read this post / thread it's saved me an awful lot of headache.
I'm in the process of replacing our Danfoss 102 with the Drayton LP722 , i did have a idea where the connections would go on the Drayton unit , but to be honest i was a bit out.
Many thanks to the original poster & the people who answered his question perfectly.
Went it arrives i can now fit it with 100% confidence.
