- Joined
- 12 Apr 2020
- Messages
- 466
- Reaction score
- 0
- Country
I have a painted bath panel, which sits under the rim of my bath and is flush with the edge of the bath, as the instructions said.
I just took it off to check the plumbing, and found water was creeping around the bath rim and sitting on top of the bath panel, and leaving a bit of a mess. Also over time this will not be good for the panel.
Is there anything I can do? I need access to underneath so I don't want to seal it with silicon. Can you even seal a gap like that with silicon nicely? I've only ever siliconed corners, not a gap between two things
See below
See below
