Is the plumber telling me fibs?
Beds get moved.
True
One also needs to Consider where a central. Jesting header tank ( cistern,) is sighted?
Solid fuel boilers /wood burners should have
Metal feed and expansion tanks
And metal. Over flows
Copper floats in the ball. Valves
Imo
Another case district heating in an old people's complex
Old girl went to. Get out of bed fell and got stuck between the bed and radiator
Heating came on and cooked her
She died
A case for low surface temp radiators may be
A woman I once worked with was a diabetic. She went home one night and collapsed in her hallway and her arm ended up resting on a surface mounted central heating radiator pipe. Heating was on while she was unconscious for some time and burned her flesh right down to the bone. She was off work for ages and had to have skin taken off of her leg to be grafted onto her arm. :eek:
Mains fed un vented storage cylinder has potentially enough explosive power equivalent to 3 pounds of tnt :)
If and it's a big if
XYz happened it would go up. Through yer roof like a rocket :LOL:
The options to locate tanks in fink truss rafter roofs are limited and specifically designated by the designers and are usually illustrated on the drawing.
AFAIK there are no regs as such? As to where tanks are located in lofts other than decent support for the load?
Had one in a school were they specced a boiler and un vented cylinder in a loft space directly above a dormitory??
We were not happy with it and insisted that a frame and false floor was installed
The floor was tanked out with a drain to out side
But there were no building regs as such? That we were aware of
That's why you are plumber and have probably never seen a working drawing in your life.(y)
Who said anything about reg's?
I litre of water can create 1800 litres of steam. :eek:
U vented cylnder 200 litres do the maths
Potentially over 300000 litres of steam
3 bar pressure in. Cylinder boiling point of the water is wat?? In excess of 140 degs c :eek:
Working drawings
Regs come to. The fore if an incident occurs
Hse investigstiins are stringent ;)
And guess who wil. Be blamed
The bloke who did a drawing Nah
The bloke at the coal. Face
Builder
Plumber
Sparks
Engineers drawings and calc's supersede reg's, but also go through the B.C. checking process in any case. You really are quite ignorant.
May be so. Noseall but since u wish to turn the thread into a dispute. Or argument.
But u are really quite ignorant :LOL:
A Gammon :LOL:
Typical builder tbh ead up there arris :LOL:
