The extension will be going on the back of this house.
What i want to know, when tieing the block extension into the house, should i cut out 100mm in the blockwork to create a cavity if im to return the blocks away from the house and let the cavity continue on where ill be cutting out.
I know i could use the screw in type tie strips however if i use them, will this create a cold bridge in the corner of the new room .
