Is this a wind up or a wire up. ?
How can they have any power if I connect them to the new relay at the junction box.
Ok, lets say I locate the necessary wires like live and neutral.
What about the two I pointed out in my image.
I have identified the two wires going from the junction box to the existing old thermo.
I just need clarification on this point:
Are those wires any use to me, since they connect from the box to the thermo.
If I hook them into the relay, the relay would be connected to the thermo instead of to the junction box.
Something else to consider - presumably the system is timer controlled, so the existing roomstat only gets power when the timer calls. I assume you could use the timer output to supply the "permanent" live of the relay. The relay outputs, switched live and neutral, going to the points you highlighted on the terminal strip.In my image, I have identified the two wires going from the junction box to the existing old thermo.
Can you clarify that part?
JH
You have to replace the mechanical switch in the old thermostat with the electrically operated switch ( relay ) in the receiver.
The receiver requires main power to operate.
That couldnt be more wrong, the two wires connect to the relay from the wiring centre, the thermostat connects to the relay usind a wireless signal no wires between the new thermostat and the relayI cant just replace the old thermostat with the new relay because someone here pointed out that the relay takes 5 wires and the old thermostat will probably have 2 wires only.
Otherwise, I could have just taken the old thermostat off the wall and used the same wiring to connect the relay there. But apparently, that wont work.
Have a look at my drawing. I can't understand how connecting the relay to the old thermostat (which needs to be removed anyway, and replaced with a wireless one) will form any type of connection to the junction box.
It would be an isolated connection with nothing to do with the junction box or boiler.
Am I missing something crucial?
JH
If I disconnect them from the Junction box
Ah, that makes more sense.When has anyone told you to do that!! Leave them connected at the junction box and connect the other end to the relay along with a live and neutral and earth!!
I have a Multimeter.
