What's the smallest shower room you can have?
OM2
18 Jan 2007
Wasn't sure subforum to post this question in...
We have a small room that measures 90cm x 187cm.
We've had the plumbing done so that we can have a toilet and sink put in - but never actually had these fitted and have been using as a very badly organised storage room.
I was wondering... would it be possible to add a shower in there??
We actually already also have a vent leading out at the top fitted as well.
So, guessing it all depends on the smallest shower you can get?
Or maybe make a wetroom?
Any ideas?
Thanks.
Well, they do a 800x800 shower cubicle so you’ll have plenty of room for a wet room. Might even be able to squeeze a WC in there too! At the end of the day, if you can get yourself in there and a shower, it’s a wet room. (y)
In yachts...some of the Wet rooms are v small...just enough room to sit on the loo with a retractable shower hose.
Designed well and using the right design and size you can make alot out of a small room.
I have a wet room 1100mm x 1450mm.
I have stayed in some 'bijoux' gaffes (seaside hotels etc) and most of them have compact washing facilities.
Ventilation and drainage are usually the biggest headaches.
Pocket door. Swinging doors take up so much room
You could use a squatting toilet in a wet room floor with a rain shower fitted above it.
Not the most comfortable shower experience
No hand held shower hose permitted
we had a 750x750 tray and i extended the wall when redoing the area - so a 800x800 would fit
But the room was 2m x 750 and we have a toilet and sink in as well as the shower tray
But you can get 700x700 trays
if you have 90cm x 187cm.
you can get 90x70 trays
that would leave 1.1m for toilet and small sink
Floating compact toilet pan 480mm depth
Hidden toilet cistern ,(frame) that sits withing the wall cavity
Folding shower screen opens room up when folded in. At the time I could only find 1 folding shower screen. That was really expensive. So I had this screen made for me.
Shower space 900mm x 680mm
10 kw Electric shower control sits flush on the wall instead of bulky shower valve taking up room.
Any ideas?
Thanks.
Where the door is located will have the biggest bearing on what you can fit in there
Based on student hall wetrooms, keeping the bog roll outside or in a polly bag helps.
Otherwise one decent shower results in a soggy mess
