What is this?
17 Dec 2018
Was chiseling some new sockets in a Victorian house
And i came across this unusual (well at least to me) black thingymajig in the wall
It appears to sit between the brickwork and internal lime plaster
What is it? Perhaps some sort of damp proof/resisting material?
If so, should i avoid chiseling a socket in this area?
I wonder what size it is
and how far above the floor.
It's Newtonite lath - a damp proofing/tanking system. Yes, avoid puncturing it !
Thanks.
Unfortunately, having no idea it was there, I've already punctured it with my grinder
Is there a way to repair this?
Also, i need to fit a new radiator on a wall which contains this newtonite lath. Is there some sort of recommendation.
It's interesting how tanking is not advised on Victorian solid walls with lime mortar. The advice is to let the walls breathe and not tank
However this newtonite lath system actually works because the wall is bone dry. Contrastingly, the wall without newtonite lath is damp
is it in a basement?
No, it's in the living room.
The property doesn't benefit from a basement.
Would have been interesting to see how effective the system is in a basement
The wall does not create water, so the water must be coming from somewhere
What is on the other side of the wall? Stand back and take some wide pics, roof to ground.
Is it a solid floor?
Have you got a water meter?
Thanks.
Int
The company are still going **** newtonwaterproofing.co.uk **** and you can get mastic and special screw fixings
