Fitting a fire door in to an existing frame
Yeah that’s correct it’s to pass building regs for a loft conversion. Having to install fire doors throughout the house.
I’d like to avoid replacing all of the frames but it might be a more sensible option!
If you have well fitting solid timber doors B control may accept retaining these with the addition of additional hard wired smoke detection to all rooms opening onto the stairwell. Its a policy that was agreed by the District Surveyors assoc and most local authorities will accept this as an alternative top the approved document.
True, but once again, some BCO are over the top and ask for fire doors AND linked wired fire alarm with battery back up.
Frankly, as a carpenter I would walk away from the job you intend to do, I wouldn't even quote it.
Sometimes you have to accept that things need replacing.
There are inexpensive fire doors that will not look bad at all and all in all will cost you around £250 fitted each.
The approved doc requires fire doors and hard wired interlinked smoke detection on each floor landing.
The DSA policy allows you to keep the ex doors with the proviso they are in good condition, well fitting and solid timber with ADDITIONAL detection in all rooms leading directly into the stairwell.
ALL loft conversions are required to have smoke detection the DSA approach is to provide additional detection, there are NO circumstances where a loft conversion can be carried out without some form of detection.
Is there a link or some more info on the DSA Policy?
I'm in the same position, kicking myself that I didn't fit the 45mm frames 7 years ago when I renovated the house as I always intended to convert our loft. My frames are solid oak, some 180mm deep, they really don't want to come out. I'm confident I can trim them insitu with a combination of a router, a sharp chisel and about a day per door. I have 5 to do. I'm also considering new architraves that incorporate the extra 10mm of depth, that might be simpler. I also looked at Envirograf coatings for the doors.
I did fit mains powered detection with battery backup in ever room and have done the same in the loft, so if there's a way I can safely rely on that and leave the chisels in my workshop that would be great! I will need to change the glass on two of the doors whatever, but if I can keep my doors that would be mega.
Will I need to fit intumescent seals whatever I do and is there a relatively simple option for these that is designed for retro fit?
I'd be interested to see if anyone has a solution for this too. I've also renovated all of the rooms in my house, and installed mains interlinked fire alarms. Hence my hesitation to rip out the frames and re-plaster, paint / wallpaper the joining walls.
I've seen that you can get surface mounted seals (no idea if they're any good or easy to install)
https://www.safelincs.co.uk/fire-do...ntumescent-fire-and-smoke-seal-kit-product-1/
hi I know this is an old thread but do you cover manchester ?
if so Id be interested in a quote for fire doors
For the benefit of previous posters, the easiest way to remove a frame is to find the screws or nails holding it and work from there.
If not possible, remove the architrave, assess the thickness of the frame, set your circular saw to that depth and cut a 6 inch section in the middle of the sides, AVOIDING SCREWS AND NAILS.
Then the rest will be easily done with a crow bar.
What's a recip?
Reciprocating saw. Brilliant bit of kit, I bought one recently more for classic car work though, Cut up a knackered body tub into small pieces to fit in the back of the Astra in no time, would have took hours longer with angle grinders, axes etc. Should have got one 30 years ago.
I know what a reciprocating saw is.
I didn't know the short version of its name "recip". :rolleyes:
