I would appreciate some advice, i have planning permission for a single storey rear extension under permitted development, It will extend 6m from rear of house and i intend to do most of the work myself, with the help of family.
I have a bricklayer, plumber and sparky within extended family and i am a roofer, Albeit industrial, but roofer none the less.
What i am missing is someone with knowledge of the below ground works.
Upon submitting building control notification i found that i have to contact the water authorities to check that the development is not within 3m of a public sewer, which i did only to find that i have a public sewer running across the width of my rear garden, it's far enough away that it isn't within 3m of the extension once complete but this sewer turns 90 degrees inside my neighbours garden and heads towards, and under her property where it meets the main sewer in the street out the front.
The plan showing the sewer shows a manhole in the neighbours garden where the sewer turns but there's no evidence of this when i peek over the wall, the neighbour is quite elderly and i'm not sure that she could help in identifying where this manhole is or even if it exists.
The sewer is shown as 150 unk which i believe means 150 diameter unknow of what the pipe is made from. Going by the plan it looks to be approx 1000-1500 inside her boundary and my planned extension would be built approximately 400mm from the boundary which is a 1800 high brick wall, essentially i believe that the sewer is within 3m, my question is firstly does the boundary wall have any bearing on whether my extension is within 3m, secondly if it doesn't which i'm tending to feel it wont, how do i proceed. Do i get a drain survey and if so can it accurately map the sewer run and depth or do i need to ask permission to dig my neighbours garden to manually find the drain. Or am i getting this in the wrong order and maybe i should get bldg regs drawings first?
The attached pic shows my intended extension in red.
Any help would be appreciated.
Matt
Matt
