What's this bit called
19 Mar 2007
Hi guys..my gutter is leaking,..whst is this piece called..? Is that a small section of guttering in the middle with two joint connectors either side.. or does it come as one piece in the middle?..what size do I need? The gutter I measured is about 120mm..ts
Every bracket and fixing and pipe will have brand and size on. Buy new or look online for compatible brand if you can't source original
I'll take it off and take to b and q...the house is odd shaped lol..sloping roof , almost vertical, that's how the houses are around here..its not a dormer it's the main bedroom, just looks like that..its only a third showing, window is massive lol..apparently these house were built for miners years ago..
OK guys went, screwfix, b and q, wickes they never had the size I need.. can someone point me the correct one and where can I get this.. see pics..
Ta
Its just a connector to join two lengths of gutters together.. Guttersgoes either side...
112mm standard round brown.
I think you're right, catlad - but the OP's use of a tape measure is confusing meo_O Alastair's link is to a store that has standard brown too. Flo Plast. If it is 150mm wide - you can get it at Toolstation (not brown though)
