You can't even type your apologies correctlyYet sorry![]()
Kind Regards,John
Yet again sorry![]()
You can't even type your apologies correctly![]()
Kind Regards,John
Not at all - but I do wonder about the acceptability of product if the risk of a catastrophic failure when not in use is deemed by the manufacturer to be sufficiently great as to cause them to issue instructions to mitigate that risk.Are you trying to infer nothing can fail?
We can only speculate about what happened in this case. The initiation of the fire is, I would have thought, much more likely to have occurred whilst normal (high) current was flowing (whilst the shower was being used) than when the shower was not being used. If that were the case, 'isolating' the supply after the shower had been used would not have prevented or affected the fire.It appears from the origin of this thread that's what happened and equally could readily be sighted by the manufacturer in their defence if such a body were to attempt to turn it on its head.
Have you included this in the intended thread? Whatever, do I take it that you are referring to ...That raises another tangent as so often happens. ... There is now an OfCom requirement for ALL RADIO USERS to do an EMF compliance calculation and retain the result for every item of transmitting equipment in every mode it can operate in and every combination of equipment. This includes ALL radio equipment and the big question is how many people actually know what radio equipment they are using?
Ofcom said:Dear Licence Holder,
We are writing to make you aware of some important changes that we are proposing to make to your Wireless Telegraphy Act licence(s) issued by Ofcom.
In February and October last year, we issued two public consultations on our proposal to formally require licensees to comply with the internationally agreed levels in the International Commission on Non-Ionizing Radiation Protection (ICNIRP) Guidelines for the protection of the general public from electromagnetic fields (EMF). We refer to these levels as the ICNIRP general public limits. In October, we also issued a Statement setting out our decision to formally require licensees to comply with the ICNIRP general public limits and we recently published an update on how we propose to implement that decision.
We are now writing to you to inform you of our proposal to vary the terms and conditions of your licence(s) to require you to comply with the ICNIRP general public limits. In accordance with the Wireless Telegraphy Act and your licence(s), we are giving you notice of our proposal by publishing a General Notice on our website. ....
Yes I added it to your comment about keeping a phone is a fire proof box, which could also benefit from being RF shielded to remove that hazard too.Have you included this in the intended thread? Whatever, do I take it that you are referring to ...
Maybe the one which was 'corrected' by your edit which turned;So what error do you believe I made?
... into ...Yet sorry![]()
??Yet again sorry![]()
Fair enough.Yes I added it to your comment about keeping a phone is a fire proof box, which could also benefit from being RF shielded to remove that hazard too.
There might be other tightenings in the future of (totally different) requirements in relation to EMI, but that's a very different matter.This change could be part of a more general tightening of control. This could apply to all electronic equipment that emits electromagnetic radiation. It would create some serious problems for suppliers of Switch Mode Power Supplies and Switch Mode LED drivers,
Heck you must have caught that quickly, I editted it what I would have described as instantly.Maybe the one which was 'corrected' by your edit which turned; ... into ... ??
I must confess that I thought the error was that your "Yet" was meant to be "Yep", rather than that the word "missing" was omitted
I suppose that perceptions of "instantly" probably vary - you posted the original at 3:25 and edited it 25 minutes later at 3:50, giving me plenty of time to notice (and comment upon) the originalHeck you must have caught that quickly, I editted it what I would have described as instantly.
You are mistaken. I never make things up.No that’s not an example that’s just you saying things again and we all know how you like to make things up.
This seems to suggest one of two things.The manufacturer's booklet says to do
It would have probably occurred next time the shower was being used while someone (possibly non technical) was under it.Except this case appears to prove that MI's instruction may be, in fact possibly definitely, correct as the fire could not have possibly occurred if the isolator had been operated after the last use.
Why, it is an excellent example of MI being wrong. Not everyone on here has seen it.Winston1 change therecord. No change the image, if it is frequent then you should have many other examples.
