Decking lights
7 Apr 2020
Hello does anyone no if i can buy 3 lots of these decking lights and keep connecting them together as this 10 pack is not enough to go round the garden
In a word no. They would all need to be plugged in (or terminated ) in a water proof enclosure. You can not just 'daisy chain' them.
It that was what I wanted to do, I would have a junction and split one set left and right of it along with a cable to another junction/socket to a third location for the third set. Since the power supply is separate from the plug, I would chop off the plug and just use waterproof housings for the connections.
Each pack of these lights comes with 1 plug, 1 transformer and 10 lights. You can have a maximum number of 12 lights per plug/transformer, so you can add 2 extra lights per kit. Anymore than this and you risk overloading and damaging your transformer.
I don't know what the app is like, but when I search on the website I see stock dotted around serveral stores in my area (though generally only one set per store :( )
No, not using a single supplied voltage supply as it does not provide enough power (Watts).
The lights are 12V DC.
As 10 lights need 2.6W then
for 30 lights you need a 'LED 12V power supply providing 2.6W X 3 = 10W or more (the extra is to stop it overheating and maximize its life).
Sfk
Sfk so if someone wants 30 or more lights around there garden what can one do?
You would buy three kits.
Each kit comes with a driver.
Every driver you have will serve 10 lights.
You would provide a 240v supply to feed each driver.
Surprised no one else has mentioned this.
You can use a LED 12V dc power supply providing 10Watt or more power. And then all 30 connected together on after another. (Far ones might be dimmer)
Issue is that you have to be capable to put it in a waterproof box and wire it to a 240V plug.
Have a look at these (noting you need 12V DC and 10W or more).
https://www.amazon.co.uk/s?k=led+driver&ref=nb_sb_noss
Why can't you have three plug sockets?
Can you not just bung all this in a large enclosure?
Hmmmmm im gna have to think about this, they should make something where you can change the transformer to suit your needs
It's quite normal to fit a large weatherproof junction box or boxes under the decking, if you fit a hatch.
“They” do. Buy 30 decking lights and an appropriate driver for the 30. That’s what the professionals do. But don’t expect to get component parts for £60. Have a look at Collingwood’s ground lights.
