Hi all,
New to the forum. I've a question about corrugated bitumen panels. I've recently fitted them to the garage roof, to my knowledge correctly. There's no purlins, there never were on the old roof due to such a gradual pitch so the panels are fixed straight to the wood planks that run over the joists.
As far as keeping the roof leak free they've done a great job, however I've noticed after a few days they've started to curl up lengthways along the panel edge between the fixing nails, where each one overlaps.
Is this a problem? Will they settle again? We've had nothing like any extreme changes in temperature if that's a factor? I didn't expect as much distortion after just a few days being honest, granted I live in Scotland so you take whatever dry weather you're given with outdoor projects. I've seen these panels warp and sag on other roofs but not curling up, almost like they're trying to curl into a cylinder if they weren't fixed down.
I've attached a picture so you can see what I mean. Doesn't look too bad now but they are continuing to curl up. Any and all advice is appreciated cheers.
