Hi all,
I have a standard vented copper hot water cylinder, less than a year old, with one immersion for hot water only, no boiler. The immersion heater has a cut out in the body of the immersion and a separate thermostat. The cut out keeps tripping for no apparent reason. The thermostat clicks on and off at the right temperature, but sometimes, maybe once every couple of days, the cut out will trip and need to be reset. The stat has been changed already. Maybe the new thermostat sometimes sticks or maybe the cut out is faulty. Either way, instead of replacing the whole immersion, could I just buy an 18" thermostat with a built in cut out and then wire it to the immersion without going through the original cut out? Or am I missing something? The plumber who fitted it is AWOL. Any advice appreciated.
