I have an MDF kitchen door for a dishwasher front, but I mis-aligned some of the screw holes. Is there a way to somehow drill out the screw hole and fill it with dowel or something so that a new screw close by will hold?
is this going into the face or an edge ?
never tried this! but if it is the face then yes it might work, but would try and avoid the screw going between dowel and MDF, so maybe you will need a good fitting plug glued in a bit bigger than a typical bit of dowel.
(the screw will need to go completely into either MDF or the wooden plug - not halfway between them)
YES! I have used similar in the past.Just tap in a toothpick dipped in wood glue .
