- Joined
- 21 Feb 2021
- Messages
- 396
- Reaction score
- 2
- Country
I'm mending another drawer here, I've taken the front out (there are no dowels only a plastic fitting) as below. I've glued it up at the attachments and am weighing it down with a 5KG weight.
I want to screw a bracket into the inside -corner of the problem- side of the drawer but as you can see the (white) side is plastic. I can use wood screws for the wooden bit but should I use washes and should I use different screws for the plastic side or will wood-screws do?
Thanks.
Thanks.
