Copper tap tails
4 Mar 2013
Bradford
Will soft copper tap tails take compression fittings? Have on to swap where I'd have to alter the pipework unless I can a compression 15mm to 1/2male above it. Thanks
Could I put a compression above the tee?
I have to swap the tap, wonder if I get a new one with short flexis I could cut the pipe above the tee and put a iso valve with a 1/2 male face on the other side. Thanks
