As I said, to SUNRAY, if that's meant to be a generalisation, then what's wrong with this (per many/most of the circuits in my house)? ....I agree it can't be done, putting a intermediate in the conventional strappers will not work as long as the sw-L is at the opposite end to the line feed.
In relation to the wiring method shown in the screen shot.
Indeed it is but they seem to show it terminated at the opposite end to the SL termination.The line feed is at both switches though.
Indeed.The reason you cannot fit an intermediate is once operated you would need to operate both other switches to turn the light off
It seems that's the pattern, which I'd not come across before.Is that not reffering to the amount of switch terminals
The 2 terminals closest together. The circuit is exactly like our 'Conversion method' except it's shown with L at one switch and SL at the other whereas our 'standard' is to have them both at the same switch.I'm struggling with the drawing with the two switches.
I have drawn it out and can't get the 2 way switches to work properly.
Which terminals are supposed to be the commons??
I realise that, but I was responding to SUNRAY's statement ...JohnW2. I think the point is that the original wiring diagram cannot have an intermediate inserted, yet your diagram - which is significantly different, can and has. In the original diagram, both switches have a permanent live.
It seems that I misunderstood his intended meaning, because I thought (and still would think) that it was a general (and incorrect) statement about situations in which there was "the line feed at one switch and the SL taken from the other", rather than anything to do with the "original wiring diagram"..... pretty much all of the American descriptions show the line feed at one switch and the SL taken from the other, in which case an intermediate cannot be used.
I realise that now but, as I just wrote to sparkwright, it is not how I read your statement to which I responded - and, for what it's worth, even re-reading it now, it still seems to be saying what I originally thought it was sayingIn relation to the wiring method shown in the screen shot.
JohnW2 method WAS THE STANDARD for many years and we still see it mentioned in this forum fairly regularly, such as these from last year:Crazy way of doing it, think I have seen this once on a 70s 2 way conduit system, which I found confusing at first.
I suppose in some cases this way could be advantageous if you are trying to adapt some existing wiring, don't think I'll be bothering doing it this way if I can help it.
Simplicity maybe?Yes, I can't see any configuration being better for EMF, so I can't see any point wiring it like that.
Absolutely nothing wrong with that as long as done properly to minimise EMF radiationAs I said, to SUNRAY, if that's meant to be a generalisation, then what's wrong with this (per many/most of the circuits in my house)? ....
To be honest, after decades of thinking that was the only way of doing it, it was not that many years ago that I discovered that there were other ('modern') ways of doing it. As I've said, most in my house use that 'traditional' method.JohnW2 method WAS THE STANDARD for many years and we still see it mentioned in this forum fairly regularly...
As I said, that is easily achieved if one is using 3C+E. However, as I also said, some in my house are not done in a way that minimises theoretic EMF issues, although that has never presented me with any problems. If I'd been a 'HiFi guy', maybe I would think/talk differently!Absolutely nothing wrong with that as long as done properly to minimise EMF radiation
I was referring to the method you did a diagram of where an intermediate switch cannot be added, thinking about it I believe I have once seen this used.JohnW2 method WAS THE STANDARD for many years and we still see it mentioned in this forum fairly regularly, such as these from last year:
https://www.diynot.com/diy/threads/garage-lighting-circuit-diagram.541319/#post-4579295
https://www.diynot.com/diy/threads/borrowed-neutral.537873/#post-4540917
My words too.To be honest, after decades of thinking that was the only way of doing it, it was not that many years ago that I discovered that there were other ('modern') ways of doing it...
As an AV guy who must have worked on hundreds of AFILS I know all about the problemmaybe I would think/talk differently!
