- Joined
- 3 May 2021
- Messages
- 19
- Reaction score
- 3
- Country
I’ll have to do this tomorrow. I’ll have to pull out the cabinet under the basin again.
Did you miss this Chris !9ltrs per minute cold water. About 2ltrs a minute hot. But it comes out cold until the tap upstairs is opened.
short flexi from copper to tap but I’ve taken that off and get the same 2ltrs a min coming out of the end of the copper pipe
What’s the flow rate from the hot tap, when it comes out cold? Also what’s the flow rate in the bathroom like?
No! I forgot about the disconnection of the flexi, but no mention of upstairs flow rates!Did you miss this Chris !
Don't follow Ches ,do you mean you have taken a new supply from close to the multipoint ,directly to kitchen tap ,and there's no difference ???
The vertical section is decidedly suspect ,especially if you by passed all the elbows .
Some photo’s might help better?
Could you feed plastic pipe down through the boxed section ,and make the copper redundant ? You really need to get sight of that run.Is there anyway of checking if the pipe is blocked? I’m fully prepared to replace the vertical section if required but it won’t be easy haha.
