- Joined
- 5 May 2021
- Messages
- 9
- Reaction score
- 2
- Country
I installed the Nest Thermostat E, all went well until I turned it on. As soon as the power goes on, it trips the RCD unless the boiler breaker is off.
I have an all electric heating setup, the Nest only controls heating, not hot water. The Heatlink replaced a Honeywell 6360 thermostat which was wired as shown below. I connected the wire in the No. 1 terminal to the C terminal on the Heatlink, the wire in the No. 3 terminal to the NO Heatlink terminal and capped the wire in the No. 2 terminal - it's not connected to anything on the Heatlink. This was based on the guidance in the Nest app as I installed it, which also agreed with the Nest support site.
There was an earth wire in the wall behind it which wasn't attached to anything so I capped that too just to be safe. My understanding is that it's just a switch between the C and NO poles, so I don't understand why the breaker trips.
