Is this DPC level correct for rendering ?
26 Aug 2007
London
Hi All.
Looking at the picture below, I am concerned that that the builder has placed the angle beads at the wrong level. To provide some context the higher level where the class 2 engineer bricks stops is the actual DPC level inside the house, however I have decided to have the porch slightly lowered so I don't have to have a big step going into the property.
My concern is that placing the beads at the current level might introduce rising damp, although the render is a thin coat system where a cement based basecoat is used, and then a silicone render on top of it.
render should finish with a bell cast bead at DPC level....or at least thats best practice, certainly for conventional render
bridging the DPC is not good practice
How are you dealing with damp rising on the inside between the floor level and the higher DPC?
Thought one could have a membrane wrapped all around the edges for precisely that reason, and then the DPM as well. The proposed floor is concrete, so i would have thought wrap a 450mm DPC all around the edges + DPM, 100mm celotex insulation and then concrete ontop of that.
