replacing squeaking floor boards - 130mm wide and 18mm depth
24 Feb 2007
Birmingham
Hello Forum members
I hope you are able to help.
I have a house built in 1930's and have old floorboards squeaking which I need to replace before new carpets are fitted.
The approx size of the current floor boards are 5" (130mm) wide and 18-20mm in depth.
I have been looking all around but cannot find these sizes any where. I was wondering if anyone is aware of any builders merchants or specialist places that I can order the floorboards.
Many thanks
LK
A random search shows Wickes do them in 119mm width, that may suffice if it's a first floor non t&g board, the gaps either side being only 5mm. Or rip or plane down a larger board.
Blup
18 to 20mm thick is a pretty standard thickness, so if you are looking for square edged boards a timber merchant who offers a cutting or machining service should be able to assist. If, on the other hand, you need t & g boards, you need to consider changing to whatever width you can obtain
Blup
Hi blup thank you for your help. If I lay the carpets would it not show a line as the size is small in width?
Thanks jobandknock. I will have to explore timber merchants and see what have they got. I am not fussed about t&g as in long run if I need to lift them up it's just more hassle
Thanks lk
Thanks lk
Wooden slivers.
Wickes also do them in 137mm width, you could clamp a number together vertically and plane off the excess, if you are concerned about the carpet dropping.
Blup
Blup
I think that's the bes idea. I will pop in today to wickes and see what is available.
Thank you so much
