I have been slowly working on the bathroom, the project started when the plaster next to the old cistern was crumbling away and the cistern was a horrible old 1980's thing anyway.
I put in a new plasterboard wall and also put in a new cistern, the problem is during that I removed the old cushion floor to discover a couple of cracked floor boards (vertical ones) they are at the end of the bathroom so don't take much weight but I want to do the job properly and replace the boards, before putting on some 3mm board ready for a new cushion floor.
The problem is I cannot find any replacement floorboards that are the right depth any where. I am going from memory as the boards are currently fastened down but I have a feeling they were about 21.5mm, either way the sheds or local timber merchants don't have the right depth.
I don't want to rip the entire floor up, because that will involve replacing the landling floor too. It is just two new boards I require.
Any other ideas of where I can get these boards from? I am in the Manchester area. The house was built in the 1900s if that helps.
