Automatic laser level recommendations
16 May 2021
I'm looking to start building a wall and want to buy a laser level so that I can set everything out and get the correct levels for footings and layers etc by transferring levels etc. I'm only a DIY'er so don't want to spend a fortune, I'm looking at max £200
There looks to be lots of different types of level and I think I need one with a detector that can be attached to a grading stick/pole so that I can move around the site and measure vertical distances relative to the datum.
Can anyone recommend something for the job?
Many thanks,
Ed
Any rotating laser will do. Manual or auto, red or green.
You will need a firm level tripod, not a flimsy camera tripod, and a staff with measurement markings for the detector, so you can determine the rise and fall of levels - otherwise just a piece of timber if you are just transferring levels.
Compare the ranges of the beam and the accuracy per metre, as those are the essential things.
But can you get a rotary laser and a detector for the £200 the OP is talking about? I thought that they were a lot more expensive than that
Also, I see there are 360 degree lasers and also ones which say rotary lasers. What’s the difference? Presumably I can use a 360 degree laser with detector and measuring staff?
I've worked with a few guys who bought Huepar 360 degree lasers for interior work (search Amazon). They seem bright enough and have reasonable accuracy, although I have no idea about durability or support. I do know that they are one of the few low cost laser outfits who offer both remote sensors and tripods
Rotary lasers have a rotating head. They generally have a remote control (like a TV). They can do neat tricks like oscillating over a given small range to highlight a spot in brighter lighting conditions. They are big and expensive, but more accurate than small lasers. They have greater range, too
360° lasers use a cone to generate a 360° line. They are smaller, cheaper, have shorter range and less accurate than rotary lasers. They cost much less
BTW these 360° lasers aren't true 360° lasers - the four corner legs of the prism covers do obstruct about 1° of coverage each. I can normally live with this on my deWalt 3 x 360° laser, and its' predecessor Bosch (you just rotate the laser a few degrees on the tripod), but it's as well to know about this. Green is easier to see in daylight than red, but does cost a lot more
Not intending to hijack this post but have a question.
When a laser description says it has 'pulse mode', does this mean you get a pulsed flashing beam instead of a steady straight beam?
Just been watching a few videos on YT and the ones that have a flashing beam would do my head in!
It helps if you can see it.
Andy
I can't see how it does. :rolleyes:
You just set the level up, you can see if its rotating, and then you use the detector on the staff. You don't need to see the beam at all that's what the detector is for.
So when you are levelling on a bright summer's day you can just carry on levelling regardless ... and you don't need to wear those stupid red glasses they give you either.
