- Joined
- 4 May 2021
- Messages
- 24
- Reaction score
- 0
- Country
I’ve posted a couple of times about my detached single skin garage conversion (to insulated workshop - not habitable - no BC).
Roof is underway and I’m starting to plan out the floor. (Pics below)
as with all garages - the floor slopes away from the back to the front - but by quite a bit. 0-140mm!
The other complication is the pedestrian door height is pretty low (189 from concrete floor to top of concrete lintel) - so i need to start levelling from here at say 25mm.
my current plan is to buy / trim / shim joists to the correct depth - increasing as the slope increases (e.g 50mm, 70mm, 95mm, 120mm etc) and lay them on bed of mortar.
That way I can make adjustments to they are level and not worry about the existing floor level.
I will also attach them to either a ledger board or directly to the external wall.
does this sound sensible - any other methods I should consider?
(sorry for long post)
