We've got a boiler that needs to be covered up.
I'm going to use Ikea Besta units.
The plan: to use wall anchors. This would then allow me to unscrew the unit in 1 minute.
It's important that the boiler can be given full access.
I've had to cut sections out to make it slot in.
Just wanted advice if I needed to do something extra...?
See pics below.
This is whole pic:
I've cut blocks to fill the gap at the end. Wasn't sure if it mattered or not. But thought would be better safe than sorry.
Should I cover up the holes in the wood exposing the cardboard inside?
I don't think it would hurt if I did?
This shows the top part. Assuming the whole structure is OK as it will be fixed to the wall?
IMPORTANT: there will also be a small unit on top. Again, I'm having to do some cutting around. And will be using wall anchors.
Just looking for advice.
Thanks.
See pics below.
This is whole pic:
Thanks.
