Am building a stud wall and very limited for thickness. Planning to use metal studs as its easier to construct. It's a wall separating two bedrooms so need it to be acoustically sound. I will be fixing acoustic plasterboard to either side and fitting 50mm acoustic wool in between.
Would 50mm metal studs be OK to use for this wall? Or should I really be going for 70mm metal studs with 75mm acoustic wool packed in between?
