What is this hose and where can I get a new one?
28 Jul 2018
I've got an overly complicated tap, which has a flexible hose that has started leaking.
One end is a simple 15mm (or more probably 1/2" now I think about it (n)) female screw connection the other is a male thread, I think it's an M14 based on the measurement (it is around 14mm, or a hair over .5") but this seems odd, unusual and I couldn't find any, let alone one long enough (approx 82cm). Can anyone help me in my hour of need?
Bonus points if anyone can find where I could buy one before the other half realises the kitchen tap is broken.
plumbing threads are often BSP
the name of a BSP thread is not the same as its actual measurement.
for example, a 1/2 Inch BSP thread measures 20.99 mm / 0.825" diameter and has 14 threads per inch.
1/4 Inch BSP measures 13.16 mm / 0.518" diameter and has 19 threads per inch.
The thread is often tapered so it measures smaller at the end and gets bigger, so it gets tighter as you screw it in.
please measure yours (precisely) and count the number of threads per inch.
Thanks for the help so far. I should have mentioned it's not a usual tap connector, it's the flexible bit for a fancy tap similar to this (different brand and a model no longer available, of course)
https://fohen.co.uk/products/1xflex...I0jzP4LXospz-EqtbpwF6JBsO8AlYtlgaAoowEALw_wcB
An utter waste of money but it was here when I moved in and now I like the fanciness, so I'm keeping it if I can. I'll break out the verniers and work out how to use them again later.
1. Is it:
1a. The hose bit which connects the body of the tap to the spray head?
1b. The hot or cold connection between the pipework system and the tap inlet?
If 1a, the female connector is usually 1/2" BSP, the same as a shower hose connector.
As previously stated, you need to measure the over the threads diameter of the male end accurately. You could wrap a piece of paper round it and mark the distance (call it "a") from an edge to where the piece meets that edge on wrapping. Then diameter is (a x 7/22). Probably accurate enough.
1. Is it:
1a, and thanks.
14.7mm outer diameter for the male thread.
19.22mm internal diameter for the female thread, but i probably got that completely wrong, measuring internal diameters is trickier. I'm confident it's standard 1/2" BSP as it's the same as another tap connector (for a different tap).
Thread count per inch is beyond me, I'm a metric system person, inches and verniers is two leaps too far. :(
Yup, standard sizes for 'pull-out tap replacement hose' are male M15 and female 1/2" BSP.
Though the price of hoses aren't that much cheaper than the cost of a new tap! ;)
I know this is an old post, however I really appreciate RandomGrinch's post!
Saved us having to look at a plumber to replace the whole tap...
Had a leaky pipe, took the pipe to Screwfix, toolstation and 3 other plumbing shops to which most didn't have a clue what the pipe was or any clues on how to replace it, wife ordered a load of different ones off Amazon to no avail.
Eventually found this post with what to search for, delivered same day and fit perfectly...
So yea, I signed up really just to say thank you!
