2004 hatchback 1.4 petrol.The early Corolla was notorious for column switch failure due to corrosion on the switch contacts, but often other lamps failed too.
How old is yours?
John![]()
It only makes noise when dimmer switch is taken towards max.goes off when back on 0That's not the headlamp height adjuster mechanism whirring, is it?
John![]()
Yes it has 0 to 5 numbers on a thumb wheel wright side of steering wheel. When lights are off I can adjust brightness with this thumb wheel.only problem is when I switch the lights on then dash lights go off.Does the dimmer switch have numbers marked on it? I thought they were just marked off/on above the rheostat thumb wheel?
John![]()
A lot of people suggesting instrument panel fuse so going to replace this fuse first.hope it cures the problem.Just by way of conversation, a friend of ours has owned her brand new Toyoto Aygo for a whole four (4) weeks & the heater matrix has failed.
Good job it's warranty work ... dash out job ?
