2004 hatchback 1.4 petrol.The early Corolla was notorious for column switch failure due to corrosion on the switch contacts, but often other lamps failed too.
How old is yours?
John
It only makes noise when dimmer switch is taken towards max.goes off when back on 0That's not the headlamp height adjuster mechanism whirring, is it?
John
Yes it has 0 to 5 numbers on a thumb wheel wright side of steering wheel. When lights are off I can adjust brightness with this thumb wheel.only problem is when I switch the lights on then dash lights go off.Does the dimmer switch have numbers marked on it? I thought they were just marked off/on above the rheostat thumb wheel?
John
A lot of people suggesting instrument panel fuse so going to replace this fuse first.hope it cures the problem.Just by way of conversation, a friend of ours has owned her brand new Toyoto Aygo for a whole four (4) weeks & the heater matrix has failed.
Good job it's warranty work ... dash out job ?
