Moved into my house December 2019 with a Biasi Riva Advance HE installed over 10 years ago (found out from their service line it's not under warranty).
Had a couple of intermittent faults with it over the past 18 months but for the most part its been ok. New problem started this week - hot water flows hot/cold for a couple of mins then it shuts off completely. LEDs indicate 'safety thermostat lock out' error.
Local GSE (not Biasi affiliated) said it's possibly a sensor but could be the heat exchanger, which isn't worth replacing due to costs involved. Said he's going to speak to Biasi tomorrow about parts and get back to me.
After he left, I ran the heating full blast as it's not been on at all for a good few weeks now. While CH on, the DHW seemed to be ok - little bit of temp fluctuation but not too drastic and it didn't cut out. After running it for a few hours, it now seems the DHW is ok, without the heating on.
The morning shower will be the full test to see if it cuts out again, but does that sound like something that warrants a full replacement or is it worth repairing, seeing as it mostly functions as expected?
I don't want to get a new boiler yet as I'm planning to do a loft conversion within a year or two and would ideally hold off until then.
