Hive active heating self install
10 Jul 2021
Hi would anyone be able to help me
With a self install for hive active heating, the first thing I need to tackle is the thermostat in the hallway and my boiler is in the garage am I right in saying the wiring from the thermostat will run to the pictured fused spur ? Is this the right way to start this install any tips much appreciated
FE134599-2055-45A9-8C20-506D317E4C00.jpeg 60A55516-C303-48B6-9CBC-E6F8D2968B6C.jpeg
If you’re certain the thermostat runs to that spur, then you’ll need to safely disconnect it, or join the 2 wires (live and switched at the thermostat). You’ll need a permanent live and permanent neutral from either the boiler or spur for thermostat Hive and then the 2 wires at the boiler can go to 1 and 3 on the Hive.
From the bottom of the fused spur there is 2 white cables that run into the boiler terminal block one of these cables obviously feeds the boiler to give it power but what is the other white cable
for ?
It’ll be the live and switched from boiler, to the spur, that then feeds your thermostat.
As your room thermostat has a neutral just put the Hive single channel receiver there, you will need a link between L and 1 and the switched live in 3 of the hive , boiler timer will need to be set to constant
this sounds like a much better option so my current thermostat has a red wire to 2 an earth to 3 a blue wire to 6 and there is a brown wire that is bridged to 3 and 5 ,can you help with how I wire these to the hive receiver please
So I’ve got this far switched all the power on and there was no power to the receiver
I presumed this was constantly on but you might say otherwise , thanks for the help so far everyone it’s much appreciated
For anyone else reading this, wire colours mean nothing in a heating system, so if you are trying to do the same as the OP do not think that your wire colours will be the same
