Dear Experts,
I am dismantling my washing machine for the first time, to replace the bearings. (See: https://www.diynot.com/diy/threads/hoover-hnf-7167-washer-flashing-light-code.575646/ ).
I’ve reached the point where everything is detached from the tub - except I can’t remove the weights. There is one weight on the top and one on the front. I’ve removed the bolts from the one on the top but it won’t budge; I think it may need a gentle pry or tap. For the one on the front I’m not really sure where to start; I suppose it might be possible to get at the bolts with a socket spanner of just the right size past the door seal, or from underneath if I lifted it up.
So I’m wondering if I’m supposed to try and lift the tub out with the weights attached. I don’t actually know how heavy they are, but I’m imagining a procedure like removing an engine from a car with a winch….
Has anyone ever removed the tub from a washing machine with the weights attached?
Thanks, Phil.
Thanks, Phil.
